Right frt. Drum / Hub.
twotone68
lifetime mopar man
yuba city,ca.
Rating - 0%
0   0   0
I'm looking for the rt. frt. hub/ drum for my 68 dart with 9 in. frt. brakes. Mine stretched out the outer race seat for some reason. I'm in northern cali. so the closer to me the better. I only need a good cond. hub,but i know it all has to be pressed apart and back. Please all replies welcome. This is my daily driver so can't afford too much down time. Soon as money allows frt. disc./ bbp. conversion coming.:prayer:
You can simply score the bore and knock the race in there. Installing a new bearing of course. If the bearings are good and preload is set up right there is very little centrifugal force on the race.
Tried scoring /staking the hub twice with no luck !! Now the race has spun enough to enlarge inside diameter,so replacement is necessary. Appreciate the imput from all !!
