Rocker panel dimensions?
Rob de Bie
Member
Netherlands
New member here, with a rather strange question! I'm researching the 'Chrysler kit car' from the seventies, and in particular its chassis, shown here:
It took me quite a while before I realized that the A-body rocker panels were retained, to comply with 'stock car' requirements.
I watched two YouTube restoration videos (both Darts), and made a sketch of what I think the rocker panel sheet metal looks like. I hope I got it roughly right? My question is: what are the cross-section dimensions, i.e. the width and height? The flange height would be useful too. I need the numbers for a technical analysis.
If anyone could help me out here, I would really appreciate it.
Rob
I will get those measurements from my 73 Duster tomorrow if you'd like.
Convert, hard top, post or 4 door?
Convert has a heavy u channel inside the stock rocker.
The hard top should have the same profile as convert
Post and 4 door might be diferent
This is what I got off me 67 dart convertible.
The top 1/2 inch is estimated due to trim in place
5 to 5 1/2 is estimated with a tape measure by sight also due to rocker trim in the way.
2 3/4 is the horizontal distance I goofed when highlighting
Dana67Dart, a big thanks, that's more than expected!
I copied your drawing below, but mirrored (sorry). There's one dimension lacking to finish the drawing, top right corner. Could it be that the 1.5" measurement at the top right is also a horizontal dimension? Could you please check those two? Many thanks in advance!!
Rob
Niceolddart, many thanks for your offer! Dana67Dart already got most of the dimensions. If there's a possibility to get the dimensions of the inner rocker panel, I'm all ears. Many thanks in advance!
Rob
Dana67Dart, those are good questions, but I don't know the answers. I just know that the Chrysler kit car used A-body rocker panels. If you bought it with sheet metal, it could look like this. You could order it with 108" wheelbase Dart or Duster sheet metal, or 112" Swinger or Scamp bodywork. That's about all I know..
Rob
What I do for a fellow A body guy!
I have some better numbers I'll post in a few
from the actual measurements, then plotting them I was 0.083" difference in the overall height
There is a lot of eyeballing due to the radiused corners.
But the inner and outer chamfers are correct using radius gages unless Estimated is noted
I have been fitting my sketch to the rocker and have some minor tweaks. Ill post in a few.
Final fit.
The only thing that I am thinking is the 7" radius should be more like 8" or maybe 9", 10 is way too flat, but with the trim on I have to estimate based on the outer surface if the trim.
The inside of the rocker is shaped something like this but my car is a factory undercoat car so the dimensions are almost impossible to determine
Dana67Dart, a huge thanks for all your research and measurements!! It's much more than I ever expected. Great idea too, that paper template to check the measurements and shape! Is there any way I can return the favor?
PS: sorry for the delayed reply, I was away on a family visit for the last few days.
Rob
Just help someone else out.
You have to watch paper prints, check a known dimension in the print. My printer had to be scaled down 6% For 1/4 inch to measure 1/4 inch on the paper.
I then used packing tape on both sides to stiffen the paper print before cutting.
Where I used to work we had a 60" x 20' drag knife cutter, oh the things I could do with it today!
