scamp340
Active Member
I've read that you should place the notch on the rocker shaft to the rear and down on the right side, (the right side as you are sitting in the car). The driver's side notch should face down and to the front. I am doing some work on my 340 today that has 273 adjustable rocker gear and I've noticed that I placed the notch down, and to the rear on the driver's side. The other rocker shaft is placed correctly. I've been running this engine for about 15 years like this. The 273 shafts have banana oil grooves.
What damage have I done, am I losing horsepower? What about oiling issues as a result of this mistake? Would this cause an oil flow restriction?
