I have a 87 318 roller lifter engine with a Comp cam xe268 cam in it with the Comp supplied lifters. Can I simply swap out the Comp lifters and install my newly acquired OEM roller lifters for this block? Also, yes I have the factory short pushrods and the steel spider. Will this setup work o.k. with the Comp cam grind?
