B3422w5
We use BAM's exclusively...they drop right in!
I thought a while back you had Comps made specially for you for this exact issue
We did...I thought a while back you had Comps made specially for you for this exact issue
We did...
Are you running the stock oiling system and lifter bores? or did you do some mods to the block?crane ultra pro's have worked flawless for 9 years so far in my X block.
Just to clarify, you ran the Crane Ultra pro rollers in a Mopar stock block with shaft oiling - no issues. Correct?
Never had any problems, but the quality AND price is better from BAM.Now you don't use them? What problems did you have?
Shane@crower.com send me an email of what you are looking for.
You'd have to dial bore guage them, but they will almost always leak a lot more than if you bush them...How bad out of spec are the lifters bores in a run of the mill '77 360?
Yes they have a lifter for the R blocks with a taller body.in the taller lifter bores of the R blocks?
Did you add bronze bushings?
Kind of wondering about the accuracy of the machining. I have heard stories about how Petty Enterprises actually cut out the lifter valleys in their Cup motors and repositioned them to 1) get rid of the 59 degree lifter angle and 2) get them all in line and on the same angle.You'd have to dial bore guage them, but they will almost always leak a lot more than if you bush them...
I would imagine the shops that have the tooling to bush the lifters would be able to get them all in line and installed properly.
This will not set well with some...but I have seen machine work performed on blocks by a CNC operated by a fairly well known place here in Ca. that was pure $hit! Just because it's on a CNC doesn't mean squat. You have to choose someone who knows how to machine what you want done. Having said that, if done properly, yes the lifters will be where the factory blueprints say they should be. You'll need to supply the lifters you plan on using so they can be measured to fit the bushings being installed. Less leak, possibly better or more accurate cam timing due to proper lifter placement, which can help the lifters (both flat tappet and roller) live longer.
