1974stepside
- Joined
- Feb 17, 2010
- Messages
- 20
- Reaction score
- 0
I have a Slant 6 with single barrel Holley 1945 carb. It starts and runs fine but after awhile it seems to idle high. I notice when stopped at a light or in traffic.
Adjusting the curb idle and mixture screws do not seem to do much, I've done this in neutral like it is supposed to be. I want to get the idle as low as possible so that I can adjust the valve lash. I havent rebuilt the carb yet either (trying to postpone this until neccesary). Any ideas on what can cause this high, erratic idle? Also I did have it set perfect a few weeks ago but it went back to idling high.
As far as vacuum leaks where should I check? Does the air filter housing need to have a good seal when put on?
