sbh126
I've had a rough idle on my 383 ever since i got it. It seems to rock back and forth like it has a misfire but when I pulled the spark plug wires one by one I couldnt find a cylinder that wasnt firing. I adjusted the carb yesterday and it runs a little smoother but still not quite right. I thought I might have a vacuum leak and was trying to find it with the propane test. I wasnt quite sure what I was looking or listening for so to test it I pulled the vacuum line off the brake booster to see how it ran with a vacuum leak and how it ran with the propane next to it. Well when I pulled the line the rpms went from 650 to 950. Isnt the idle supposed to drop with a vacuum leak? Another thing to be noted is that when I pulled the line and the rpms jumped up the engine seemed to run the same. I dont know a lot about the engine other than it was rebuilt at some point and its in my 68 Polara.
