Round coil bracket info needed
SS Lancer
North Carolina
Greetings - I'm horting up all the vintage new Accel round coils that I can find to use in Dart super Stock car . Im only buying the [Chrysler P3690560] or the Direct connection 140306 which seem to be shorter and larger in diameter than the conventional round coils ??? Isn't this correct if so who sales the correct brackets that are designed for these coils thanks for any info .
I think I have a mp bracket with the sleeve to go around the coil if I’m remembering right. Is that what ur looking for. Bought it in the mid 90s. Kim
I have many new vintage round coils I will get some photos to you showing the difference etc thank you Chris.
Pics. Here is the bracket.Dont remember if there ever was a bolt. The resistor is out at my storage, will likely go out there later in the week. Kim
Ten 4
No rush
Do you happen to remember the ohms or part numer
View attachment 1715298284[/QUnumer
Ten 4 no rush do u happen to remember what ohms the resistor is ????
I have a many in general but looking for the 1/4 ohm units
Thanks Chris.
Don’t know the part# offhand. I believe it’s the 1/4 ohm if I am remembering right. Does the bracke look like something u can use? Kim
As far as I can remember. I’m pretty dam sure it’s a MP part. It is with all my other Mopar Performance stuff from the 90s. I have fender covers from Direct Connection from the 80s. I did have a K frame and chassis headers also. Kim
Ten 4 thank you when u figure resistor out let me know thanks Chris
PS how much for fender covers
