jdakota
As I was grinding off the rust getting the car prepped I noticed that the metal for one of the upper control arm (uca) brackets had rusted so badly that the lower 1/2 inch of metal was very thin and has a pinhole rust through. I was quite bummed but at the same time, glad I discovered it.
I had planned to put an AlterK in, and that system uses the existing uca brackets. So, now I have a decision to make.
1) Weld in some support.
2) Buy a Morrison or Alston complete frame and just set the body on top.
Right now I'm leaning toward the complete frame. I planned all along to put in a new front end, frame connectors, and rear clip for bigger tires. I also plan to remove the floor pan and transmission tunnel since the tranny I'm putting is is a big one. Also, most of the rear pans are coming out also for the 4 link.
So, why not just buy the complete welded frame? It seems like it would be easier to do.
My main purpose for writing this thread was to give some awareness to those
brackets. I haven't seen any dialogue on A bodies that spoke to the issue.
I would recommend anyone with a 67-69 Dart to check the integrity of those brackets. I think mine would have failed had I not caught it.
