Sam's ATF
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
So on the way home from work I stopped in at Sam's whorehouse to get some transmission fluid
I usually get the super engineered brand or whatever it was for 20 bucks a case. It used to say Dexron mercon III which is familiar and works on everything.
Today I get there and this is all they have, WTH is this ??
It's almost ridiculous how many different atf's are out there. Especially for imports...use the wrong one and poof there goes your trans.
It must state somewhere whether it's on the box or the bottle what it's compatible with. You should yank one out of the box and read the bottle.
All that said, you don't have to be picky about transmission for a three speed Torquflite, little one. They'll run on motor oil. That's a fact.
I got away from buying quarts a while ago and use 303 Hyd oil. rice is right only issue I have with it is it is clear so hard to see on the dipstick.
DAM , I read this this morning and didn`t even notice the whorehouse part until u guys started ribbing her !! Guess I`m getting old -----------------------------------
