SB360 cam degree centerline?
67Dart273
Idaho
Muddog called, he's "typing disabled, LOL" wants to know the best place to stick this cam on a new build
http://www.summitracing.com/parts/dcc-4120653ac/overview/
MP 4120653AC
Going into a Dart, 360, 4 speed 3.55. Sounds like he's shooting for 9-9.5 compression, street use
Found this: shows a 110* intake centerline so the question is, do we want this at 110* or where for best street?
http://victorylibrary.com/mopar/mpcam-tech-c.htm
284° Mechanical: P4120653
Intake Duration, Nominal
284°
Exhaust Duration, Nominal
284°
Intake Duration @ .050”
241°
Exhaust Duration @.050”
241°
Intake Lobe Centerline
110° ATDC
Exhaust Lobe Centerline
114° BTDC
Lobe Separation Angle
112°
Overlap
60°
Intake Opens
32° BTDC
Exhaust Opens
76° BBDC
Intake Closes
72° ABDC
Exhaust Closes
28°ATDC
Intake Lift
.528"
Exhaust Lift
.528"
Note: as installed on 110° centerline per Chrysler
I'd go 106-107
That is a really good cam for an old school design. Have one in my 340 and it's installed at 107.
Thanks Cracked. He's on his way home, if I understood right, the block/ crank / etc are at the machine shop now.
I've always run them straight up. There's no problem with low end with them unlike many of the hydraulics - it needs to be degreed to verify the ICL but I'd leave it at 110°.
