I just picked up a repro rear window seal for my '68 Dart from Classic Industries, so there are some seals out there. Haven't installed it yet, but a "lay it over the back window" fit check looked OK. I would wonder how the headliner is trimmed out around the back window with the sealless install, since the headliner edge is pushed under rubber seal. The window moulding on the outside probably doesn't fit very well either, since its supposed to rest on the rubber seal. Guess you could use really thick sealant strip to move the window outward....
