Sleepy,
Here's the specs...all work by my lonesome except the trans build and block and head machining.
New engine is an Original 360, Currently CID 408 Approximate 580 hp
91 LA block .030 over, zero deck, line bored
Hughes Main girdle
Extensive oil system mods
Melling standard oil pump
Kevco oil pan and pickup with larger tube
Scat forged 4.00 crank
Scat H beams con rods
Keith Black forged pistons
Edelbrock Magnum Heads fully CNC ported by Hughes, 2.08" intakes, milled back to 58cc chambers. Around 300 cfm @ .600 lift
10.65 static compression
1.6 stainless steel rocker arm
ARP head and main studs 190 Ksi
Hughes Camshaft
o Intake Lift .610
o Exhaust Lift .614
o Intake Duration @ .050 valve lift 252
o Exhaust Duration @ .050 valve lift 256
o 106 degrees Lobe separation angle
Solid lifters with EDM holes
Port matched Edelbrock Air gap Intake
850 Quick Fuel Carburetor
TTI Industries 1 7/8 Headers
TTI Industries 3" dual exhaust with X pipe to the rear bumper
SFI Certified Damper and Flex Plate
Mallory Magnetic Breakerless #42 Distributor
Mallory Hyfire 6AL Capacitive Discharge box with rev. limiter
Edelbrock 160 GPH pump
Dual Fram Fuel Suction fuel filters
-8 AN lines to regulator and -6 AN to carb
Fuel Cell and battery in the trunk
John Cope racing transmissions built 904 Torqueflight
o Manual Shift Reverse Pattern
B and M Pro Ratchet Shifter
PTC 3600 rpm torque converter
1350 Spicer U-joints on custom 3 diameter .083 wall drive shaft
Moser 8 3/4 nodular center section with Richmond 4.10's gears, Moser Alloy axles and Auburn Sure Grip
Wilwood Discs up front
Billet Specialties Wheels
B.F. Goodrich Radial T/A Tires
Custom BeCool Aluminum Radiator
HP High Flow Water Pump
Caltrac Traction Bars
5 Cowl fiberglass hood
Recently Painted original Y8 Gold Poly
Currently Weighs 2,920 lbs. without me
