six pack with nitrous questions
LETSRACE
Near Chicago
Anybody have a six pack with nitrous. I heard that dual plane intakes are not good for nitrous execpt the 3x2 set up.
The 6bbl NOS setup (plates) only use plates on the outboard carbs. The dual plane deal is bullshit. I've done it a bunch of times. You can run it on anything that pulls in air and fuel.
The dual plane thing is indeed a lie, I think it was Hot Rod that tested it against a single plane (SBC of course) and the dual actually did better on a dyno lol wouldn't of guessed that.
as long as the manifold doesnt have seperate holes for each barrel on the carb, you are good to go!
The manifold is a Edelbrock 2480 with six seperate holes. I looked around for a 6 pack manifold with only 3 openings but was not able to find one.
Makes sense as the middle 2 bbl is the 'primary' carb and should handle all requirements of part-throttle cruise. The end carbs should only come in as the 'secondaries' during full-throttle application.
Or if you got the $$$$ go with a fogger system but you might have a problem plumbing the last runner on the DS
