Slant 6 to V8 engine mounts [NEW ]
This might help
looks like he copied the garbage transdapt mounts. or maybe they are just transdapt mounts. be curious how they nice they fit..
about 15 years ago my buddy had a pair of Trans Dart mounts that had worked fine on his Dart. Being the cheap*** that i am i made templates and cut and welded up a pair out of 3/16" mild steel plate.They were a good fit on my next duster project.The only thing i did different was drill the mounting holes 1/2" so i had some wiggle room.
A couple of years later while i was at Carlysle i compared my templates to the Schoemacher mounts and they were the same dimensionally.
Maybe as Rusty says the quality may not be the same now but they should still fit fine.
I have transdapt mounts on out dart. They work but just aren't as nice as the schumacher ones I usually use. Just a lot more rough in my opinion.
So is Schumacher done making mounts?
I just tried wanted to talk with a Human for a response for u and this is what I got !!!
As long as they work without modifications. Probably someone bending them up in their garage at home. LOL I have a friend with a plasma table. He could cut out a 4x8 sheet of them if needed. Na, I don't want a full time job again. LOL
Street motor blistering the tires want never break um !!!
