Slant six over bore .080
won't touch the pistons , going to speak with my machine shop there really good been around over 40 years
been dealing with them since mid 80's
When you use the original Buick piston and pin and bush DOWN the rod.... Press the .901 bushing out of a Mopar rod and press in a .825 ID bushing...... You gonna bore 6 Buick pistons and remove .026 to fit a Mopar rod or are you gonna buy 6 .875 ID bushings and press the Buick into a Mopar rod. Set up and machine bore and then hone 6 pistons or press a bushing into 6 rods? Id do the machine shop estimate before I chose between those 2. And 2 more for your 2 extra V8 pistons.
No. I would hone the Buick piston out to the Mopar rod and press the Buick piston on.
I bought a spare engine ( now 2 spare forged crank , and 81 dippy engine) and it came with the later head
already rebuilt , im thinking of porting it and using that head instead of the 67 one
lots to think off, I m taking a week to take car of personal stuff, before I \satrt some winter restorations projects , im so over booked with covid , people are spending on cars what they didn't on vacation!
im going to see what the motor shop says , im 30 over already , but wanted more just cause.lol
If the Buick piston can be made to work it would be an excellent choice to get compression up with the stock 225 rod.
im already at 9.5 , the head shaved .100
I was on the highway going home and this modern mustang and gunned and the stand had a hard time catching me. he caught up with me at the light and he though I had v8 , then he saw my set up at the local burger stand meet up, and now he is looking for a slant six!!
Them bushings are gonna be so thin that there won't be enough of them for adequate support, I bet they get pounded out in short time
Right. That's why I would advocate honing the wristpin bores. You could damn near do it with a brake cylinder hone.
I was under the impression that later model blocks had thinner cast walls in the cylinders and had lower limits on acceptable overbore size compared to earlier blocks. Being a '79 block isn't he already at/near the limit at .080 bore oversize?
