Small Block LA Driver Vs. Passenger Side Heads
540slant6
Mopar SB Ripper
Berryville, VA
I have a set of 360 "J" heads and they appear to be identical. I'm assuming each head can be installed on either the passenger or driver's side? i.e, they will work on either side of the block and are reversible. I know, probably a dumb question but better safe than sorry.
Thanks Fellars
Interchangeable. Now one may've had the front modded for the brackets when it was on one side or the other but that doesn't change that they are the same stock. With Js, shouldn't be a thing to worry 'bout at all.
