Small Block Showroom!
My 273 in my 66 Barracuda. When I put the vintage Offy intake and Holley carb on it, I couldn't use the super cool stock air cleaner. So I bought a black crinkle air cleaner and a 383 commando pie plate from Mancini Racing. Then I had a local sign shop make a 273 sticker to go over the 383. Not OE but I felt like it is a respectful representation.
4" stroked 360 in '67 convertible. 445 HP at flywheel
4-1/8" stroked 360 in '67 notchback, work in progress. 568 HP at flywheel. 91 octane motor
What are the specs on that 568hp stroker? Those are the numbers I'm after.
I asked the builder for a reliable high-performance street engine that runs on 91 octane, and has a smooth idle.
0.060 over magnum 360 block. 4.125 stoke crank. Crank is made by K1, but I don't think K1 makes that stroke any more, so you would need to find another manufacturer.
Ported Eddy magnum heads, 308 cfm at 0.50 lift.
10.2:1 compression ratio.
Molner rods. Diamond pistons. Hastings rings. Morel lifters.
Indy intake with 1" carb spacer. Holley 1000.
TTi 1-7/8" headers
Comp hydrauilic roller. 0.586 in/ex lift with 1.6 rockers. 112 lobe separation. Durations at 0.50 lift are 242 in/248 ex
MSD ready-to-run distributor. Best HP was at 31 degrees timing
568 HP at 6,000 RPM, 545 Ft-Lbs @ 4500 RPM
Just for fun, we also tried some other intake/carb combinations: Eddy air gap rpm with Eddy 800 carb produced 534 HP and 544 ft-lbs . Eddy air gap rpm with Holley 1000 produced 550 HP and 559 ft-lbs.
Here's my 318 - bored +0.060", 9.8:1 comp, KB167 pistons, prepped factory rods with arp bolts, reground factory crank, windage tray & baffled sump. Alloy heads with minor port clean up/bowl blend and good valve job, 1.6 ratio rockers with B3 kit, cam is a howards SFT [email protected]" & .574" lift. Ported weiand action plus intake and 650cfm AVS2.
@RogerRamRod Here is a pic of one of our "off the shelf" RHD headers - options are pretty limited
Up till 2:00 am with the engine hoist so I could close the garage door but my 360 crate is in its dirty home(71 Demon).
Just have to put all extremities on.
Should make a fun little s#!tbox.
Small blocks in A bodies rule!
Long time viewer... first time small block.
Working on a 65 273 to replace the 225 in my 64 Valiant (Yes, those are B-body exhaust manifolds...engine came out of a 65 Belvedere)
This is the 1970 318 in my Dart. As a kid, I set it up with a competition cams 268H, single plane intake and Holley 750, and 360 J heads. Not the optimal combination for power, but it was still fun. Hopefully I get it running again!
All those mud dauber nests ought to make that fun to work on...if anybody's home!
What is the combo on this motor?
Normal stuff. 72 340 thermoquad, factory 71 intake and exhaust manifolds. Ported j heads. .030 over bore 4.125" stroke. Decent cam. Car is a 71 duster, all steel, full interior, 6" polyglass tire.
Correct it’s cruise control, I’ve installed a few of them now.
I added CC to mine as well, but I used factory stuff.
Working on a plan to use the original turn signal stalk and CC buttons when I do my G3 swap so cruise control works like it does in a 2009-10 Challenger without a module in the engine compartment.
I am seriously impressed with some of these engine bays. Some of them look like there are zero wires, very clean
My current Dart looks like it has enough wiring for 3 more cars
68 block with 71J heads and mild cam. Doug's headers are going to be installed in two weeks.
340 .030 over.
