Yes and yes!
Bruce! Hell yes,200 times.....(frame connectors).
Yes and yes!
You will need moar fuel line IMO but maybe not. The stock line isn't enough with a sucking fuel pump IMO. When you get the dyno sheet it will show you how many gallons per hour you are eating at full power. You could weld on a sump and put an elec pump on to push the fuel up front through the stock line and have the regulator up here near the carb. That is what my fish had. It worked at 500 HP. It will get AN-6 lines now with a pump and filter at the rear, drawing from a sump on a new Canadian tank.
550 HP sounds enticing and fun, something I may want to try someday. Will that engine run on pump gas? Also would that power level require torque boxes or frame connectors?
