pettybludart
Can,t Mike from MRL build you something a little milder than 550hp??I,m sure Mike could build you a 360 with some good heads and go fast parts in the 450hp range,for cheaper than a stroker cost.Just a thought.
Ya, I realize that the Dana was going overboard, but it was my cheapest route to a 4.10 posi to replace my noisy 7&1/4. - Plus it gets the car a little closer to resembling a factory Hemi Barracuda. My first choice would have been an 8&3/4 but I didn't want to spend what people were asking for them. Most that I'd found were either single tracs, needing rebuilt, needing narrowed, or a gear change. The Dana cost me $300 before I had it narrowed and disc brakes added. I figured I'd have spent more on an 8&3/4 to start with and still had the same expenses narrowing it and changing brakes. - Plus I would most likely have had to shell out for gears.
The extra horses it takes to drive that Dana shouldn't kill it for the street.
Very good point about A-body 8 3/4 rear end pricing. Sellers are pricing those to the point where brand new large bolt Dana rears are near viable options.
Sure the Dana is overkill. But by the time you add all the goodies to a core A-body 8 3/4 the initial core price can kill you.
Can,t Mike from MRL build you something a little milder than 550hp??I,m sure Mike could build you a 360 with some good heads and go fast parts in the 450hp range,for cheaper than a stroker cost.Just a thought.![]()
I couldn't justify putting bucks into the 7&1/4 unless I was doing a true restoration. By the way, autoxcuda, how'd those tail lights work out for you?
Awesome, thanks. Polished up my nice housings for them. Now need to repaint the black pinstripe and silver innards. After that straightening, polishing, and painting the trunk trims....
What's nice about a stroker is you can get the performance out of a tamer more streetable motor. And easier on valvetrain. And they soak up cam.
I put in a Scat balanced rotating assembly from Brian at IMM Engines. Measured up on the money when double check everything.
what is the difference in weight between an 8 3/4 and a Dana
So you would recommend Indy. Thanks.
Good machining costs money. As does dyno time especially when you don't own one. However, you should be able to achieve your goals without dropping $9K, even with Mike building it. Ask him to do something lower budget than his "550hp recipe" deal. There are many decent shops, and probably something closer, and plenty of decent "power recipes" around. You should be able to get something under $6K with decent parts in it.
In regard to the other link - I'm not familiar with the site but the posts lead me to believe they have their heads up their asses. A little knowledge is a bad thing...
do not do a burnout in 1st with a 727. You can start in 1st but short shift to 2nd as soon as the tires break loose.
340Fastback, I haven't talked to Indy yet. What types of issues have you heard about?
Let me counter with a minus 10 recs for Indy. You will regret doing bidness with them. 2nd the rec for MRL. If you are not in a hurry you will find deals on strokers that are well built and ready to drop in.
Do not do a burnout in 2nd with a 727. You can start in 1st but short shift to 2nd as soon as the tires break loose.
I have made the mistake of buying a block and rotating assy from Indy. They do not deliver what they have charged you for and then they lie and deny when you call them about the problem. They get your money and you are stuck. Avoid!
And that is a sweet Dana. Would look under my 68 fish with my 416/904.
That 550 HP stroker Mike is describing sounds like the blue motor he posted here about a couple of years ago. I was so impressed with the power I bought a set of heads, his lifters, and Hughes 1.6 rockers as well as the solid Lunait cam he used to upgrade my pump gas comp 292H/ported Eddy head 416. Still have not had it in a car but it is ready with a 11" PTC converter and fresh 904 (with kickdown on a VB that allows automatic or manual shifting).
Here it is: http://www.forabodiesonly.com/mopar/showthread.php?t=189967
One more thing... You should be able to fit 275/60-15 DRs under the fish fenders on an 8" wheel. I have the SBP 8 3/4 in my fish using Wheel Vintique rallys and the combo looks fantastic IMO. Fronts are 14" on drums, so far. Great stance. Those wheels are heavy BTW.
BTW, crackedback has a MP 508 and that Comp 292H is about the same cam, I think. To each their own I suppose cause I loved the idle, power (cam came on at 2500 with a single plane intake which was where the vert started working solid), and sound. My car at 3050# and a 2500 converter and 3.91 gears went 7.20 at 98.
..too bad there is no experience yet with that ATK 408.
Sounds decent,2 year unlimited mileage warranty and great price ....5499.00
