73 Shwinger
Active Member
I have a 73 Dart with a 360 in it....what will it take to mount a 440 in it's place??
Many posts on this, use the Search. Need special motor mounts, different transmission, driveshaft, maybe a different rear end, maybe an aluminum radiator, stiffer torsion bars if a street driver. Headers often need a cutout in the fender wells. If not, the exhaust is choked so much the BB doesn't make much more power than a SB. The result is hard to handle on the street and most people do it to make a drag racing only car.
On a 73-76 small block k-member to big block Schumacher kit you CANNOT go back if you decide to. That kit requires shortening the driver side motor mount saddle. Spend your money on Schumacher if you want to. I'll save that money for other parts.
