small vs large sector steering box case size
darto
Petaluma Ca
Hello does anyone happen to have the dimensions/ spec sheet of the small sector steering box? I currently have a large sector box in my 1967 Dart and it is hitting the TTI w2 headers at the top by on the cover plate I removed the bolt but it still hits the cover. (The engine is sitting properly as per TTI specs) I was wondering if cases are different and if changing the box would fix this.
Thanks,
Rob
I'm looking specifically for the measurements where the arrows are as the small sector box looks like it is different from the large sector box.
I didn't know you could even interchange small and large sector gear boxes, since the steering linkages were different from 1972- and 1973+ cars. In early cars, the Pitmann and idler studs point up, or at least do in my 1964 & 65 A's (different still since narrower cars). Perhaps you can get a custom Pitmann arm to fit both your linkage and a small sector gear box.
