draginmopars
finished fitting the crossmembers
loops are under the front seat
won't be seen
they are welded to the top of the trans tunnel
and where they go through the floor
the front one - cross member is bolted to frame connector and loop
to be removable for trans maintenance
the second one- is welded in place
also serves as a drive shaft safety loop
the new floor section sat in there pretty good
considering the old floor is still there and the wire protector plate are holding them up some
now, gotta taking all back apart
to paint the non-access areas between the floor, connectors and tops of connectors
then final weld in place
will then cut the spot welds off the old front floor, install the replacements.
and a small patch
won't be seen
and a small patch
