BWDart
What do ya'll use to soak an edelbrock? Won't fit in a gal can would one of those disposible aluminium pans work or will the cleaner eat thru it?
Thanks
Thanks
If it eats the pan, ill damage the carb. Try a cut down dollar store trash can. They have lots of sizes there. Berrymans will damage the finish if left in overnight. I may have still had the 'good' stuff but it made the boosters very porous, like it ate parts of the alloy.
I thought my carb was dirty yours really needs a good soakinI'm doing a carb right now and I found a thick plastic bowl that the center of the carb would fit in and then added other stuff around it to raise the level of the fluid to cover most of the carb
