1966DartConvertible
Look at what the previous mechanic did (before I took the car)
This is the old carb (Solex) setup ... check out the flange...
He ground and welded the original setup and put the new carb with the flange Fwd-Aft orientation. Original Holley 1920 should be left to right.
Now I have to grind the weld off and see if I can install the 1920 the correct way! Errr...
Syed
Syed
