SPC UCA's?
I would not be the first guy on the block to trust the bolted-together arms. Those have four more failure points than other arms... Might be ok...for somebody else.
I was also thinking of using those seen them on a Chevy at work . I went with badart aka johns tubular upper and lower control arms for my coil over set up
I use and sell these regularly. I also have them on the Dart now. They have been selling these for GMs for years. Since the bolt together design is in double shear its nothing to be scared of. It's the only real double adjustable arm on the market. It makes aligning so much easier and affords the largest range of adjustment on the market. Too bad nobody knows about them.
