Speedmaster Small block porting tips and results
Mopar Racers Forum
  1. pittsburghracer
    pittsburghracer Well-Known Member
    2,797
    5098
    Apr 20, 2016
    Freeport, PA.
    Local Time:
    11:26 AM
    You know which one. Lol. Of course the one I posted the numbers for. Very fixable
  2. yellow rose
    yellow rose Doctor of Thinkology.
    20,513
    16594
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    8:26 AM
    LOL.
  3. cookietruck
    cookietruck Well-Known Member
    738
    135
    Jun 25, 2012
    alkdfnoi
    Local Time:
    10:26 AM
    i know there was a post about this somewhere...but there are so many junk posts in all these threads i'm gonna just ask.
    these speedmaster heads (and therefore, sidewinder and edelbrock) can use an 11/32", 4.911" long "chevy" valve right???
  4. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    15,145
    3543
    Jan 16, 2005
    las vegas
    Local Time:
    8:26 AM
    No...11/32 5.011 valve
    • Agree Agree x 2
    • Like Like x 1
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      5,061
      4041
      Jun 1, 2016
      Beach
      Local Time:
      8:26 AM
      Can and should, 2 diff things.
      Sure they could, if you use all that stock oriented crap and limit the whole thing.
      Are you lost?
      • Like Like x 1
      • pittsburghracer
        2,797
        5098
        Apr 20, 2016
        Freeport, PA.
        Local Time:
        11:26 AM
        I finally picked up a new thickness checker (sonic checker) last week and calibrated it for steel, cast iron, and aluminum. When I finish up my 408 shortblock I will do some testing to see if the Speedmaster heads have less water in them (floor) than the Edelbrock heads do.
        • Thanks! Thanks! x 4
        • Like Like x 3
        • yellow rose
          20,513
          16594
          Jun 19, 2015
          Local Time:
          8:26 AM
          What did you buy?? I should probably have one at home.
        • pittsburghracer
          2,797
          5098
          Apr 20, 2016
          Freeport, PA.
          Local Time:
          11:26 AM
          TM8812 Ultrasonic Thickness Gauge 1.2-200mm,0.05-8inch
          I paid 220.00 for it from Amazon. Its listed on ebay for 160.00 but the guy had some VERY bad reviews, the shipping date was very open ended, and his ad said you may have to pay import duties. I ordered it on Tuesday and had it on Friday. I will at a later date order a smaller 6mm probe. Amazon doesn't list it at times. I started a post on Yellowbullet asking for suggestions and was told this one was rated highly by the members of Speedtalk.
          • Like Like x 2
          • Thanks! Thanks! x 2
          • 360duster
            360duster Well-Known Member
            1,176
            283
            Nov 23, 2008
            Bavaria / Germany
            Local Time:
            5:26 PM
            interesting, let us know how accurate it is. Such thing is on my wish list….really like to know about wall thickness when doing an engine.
            Michael
            • Like Like x 1
            • justinp61
              justinp61 Well-Known Member
              1,366
              665
              May 15, 2009
              Local Time:
              10:26 AM
              John, does it have a place to select which metal you are checking? The reason I ask is the guy that did my block said he calibrated to the metal he was checking.
            • pittsburghracer
              2,797
              5098
              Apr 20, 2016
              Freeport, PA.
              Local Time:
              11:26 AM
              The meter has cd01-cd11 to set from for anything from steel glass pvc copper etc. trouble is when setting it that way you have a cast iron setting, gear cast iron, modular cast iron. Using those settings I think the closest I got it was .020-.030 and who would really know. Heck the one iron setting was .100 off. Using it manually I am setting it to a part of a know thickness. I plugged in the cast iron setting I programmed in three days ago and checked the motor mount on my engine block. There was .002 difference between the checker and my Harbor Freight digital calipers. That’s close enough for this guy. I found the manual setting to be.
              6350 aluminum
              4950 engine block
              5890 steel
              That may save someone some time. I don’t really have a lot of time to play with it now but wanted to check it out in case it didn’t work. It has a .198 steel button on it to calibrate to for steel.
              • Like Like x 1
              • pittsburghracer
                2,797
                5098
                Apr 20, 2016
                Freeport, PA.
                Local Time:
                11:26 AM
                Just for example I put in the setting for aluminum that I set from check a piece of aluminum bar stock. It read .250 exactly like the other night. But checking an Edelbrock Head that setting is way off.
              • gzig5
                gzig5 Well-Known Member
                1,023
                971
                May 3, 2018
                Mequon, WI
                Local Time:
                10:26 AM
                Aluminum bar is extruded and a head is cast. Different alloys too. Makes sense they are different because the densities are like night and day between them.
                Love to have tools like that but can be hard to justify. But if I don’t have to drag the block to a shop and pay them it may be worth it.
                • Agree Agree x 1
                • K.O. SWINGER
                  K.O. SWINGER Well-Known Member
                  1,065
                  300
                  Nov 18, 2010
                  oregon
                  Local Time:
                  10:26 AM
                  That's really cool Pittsburgh, so much speculation can be eliminated keep the post coming!
                  • Thanks! Thanks! x 1
                  • ou812
                    ou812 Well-Known Member
                    1,441
                    297
                    Jan 15, 2005
                    SoCal
                    Local Time:
                    8:26 AM
                    You have to grind a "flat" in the area you want to check...sonic testing ports is difficult.
                    • Agree Agree x 2
                    • pittsburghracer
                      2,797
                      5098
                      Apr 20, 2016
                      Freeport, PA.
                      Local Time:
                      11:26 AM
                      Ohhh I hear you. There are very few times I even worry bout it, until I want to do some questionable blending. That 6mm probe would probably come in handy.
                    • justinp61
                      1,366
                      665
                      May 15, 2009
                      Local Time:
                      10:26 AM
                      That's what my guy did, he set it up on the main web on my R1 block. He also said that the material that it it was calibrated on could change the accuracy. If it was calibrated on something like a normal production block and then used in a high nickel content block the measurements would be off. That's why he calibrated on the block he was checking.
                      • Agree Agree x 1
                      • pittsburghracer
                        2,797
                        5098
                        Apr 20, 2016
                        Freeport, PA.
                        Local Time:
                        11:26 AM
                        Like I said after you get used to manually setting it, it’s not that complicated or time consuming.
                        • Like Like x 2
