3 things:
- Sometimes the insertion of the cable core (or connection the whole cable assembly at the trannie end) does not properly engage the square end of the core into square hole in the speedo or trannie gear. The core will then erraticcally 'catch' and 'not catch'. I've had to turn the core manually at the trannie until the core is lined up so it will go right into the square hole in the trannie gear to make them mesh. I've also had to do the same thing at the speedo end.
- If the cable's outer jacket is stretched, then the core end can partially slip out of the mating square hole at one end of the system and make erratic connection.
- If the delicate springs inside the speedo break, it will jump around. You have to replace the speedo/dash cluster itself.
