7duster4
I'm trying to determine if I need a new speedometer cable. The rear end in my Duster has been upgraded to a 3.21 gear. Afterwards I replaced the pinion with the correct one (32 tooth) When driving down the highway my odometer is almost 10% off when the needle is around 70mph. I remember when I first bought the car the odometer was slightly off. What else could cause this since the pinion has been replaced? Do I need to replace the original cable with a new one?
Any info is appreciated. Thanks
