Stall Converter help please.
ramrod340x
Member
Cambridge Ohio
I have a 71 scamp 318 .60 KB 399 pistons 11.3 to 1. 62cc milled 360 steel heads with lots of work 2.02/1.60 super Vicktor intake 750 BG silver claw carb MP 590/312 solid cam 265 at 50. JR fender well headers msd 6al and pro billet and baster 2 and wires eagle H beam rods 273 steel crank moroso eltc water pump TCI comp 727 cheata reverse valve body 8.75 rear end with 4.86 gears 26" MT ets. the thing likes RPMs so what converter? It has a tci 10" 4100 flash but it not enough. It dont leave hard. HELP brand and stall numbers please.
what are you 60 ft times?
well..with that small engine...and big super victor intake...big MP590 cam...
you are going to need a converter that will flash upwards of 5500 rpm...318s dont make alot of torque so it going to need to be
a loose one...
and with 26 inch tall tires with 4.89 gears.....the rpm is going to be even higher in the traps....
pretty mismatched combo you have....
i saw another post where you stated it runs 12.20s at 101 mph.....
Is this for 1/8 mile with the high gears and small tires(4.86 and 26 inch tire)?I use a COAN 8 inch 4500 stall in my 410sb with 29inch tire and 4.30 gears.Sounds like you,ll be out of steam by the 1/8 ft mark.JMO.
Its not out of steem in the 8th. Im only about 6200rpm in the traps in the 8th Its way out of steem in the 1/4 but the 1/4 is a once in a blue moon thing like the nats. it just wont leave hard it pulls great at about 60ft on but my 60 ft sucks.
a loose one...
60 ft is 1.77
what i would do is call dynamic, ptc or ultimate converters and get them to build a converter for your combo. the biggest thing when having one built is to be 100% honest about your combo and your intended use when they ask.
