Okay, you guys have helped with every issue and hopefully this is a small one. Okay I have a 318 block with 360 heads with a Comp Cam 268H. I have the throttle body bolted to the top of the stock 318 intake manifold.
Issue: In park the motor runs great, soon as I put it in gear it wants to stall. It has an automatic transmisson. Park and Nuetral it wont stall. But soon as I drop it in drive and drive it 100 yards stop at a stop sign it wants to stall out. I have to pop it in nuetral and give it a little gas and drop it in drive to get going again.
Another thing that happens. I will drive it for a period of time and say a mile about and stop a traffic light it sputters and goes to stall..i have to pop the thing in nuetral and rev it up to keep it going
At first I thought it was oiling problem. But I changed the oil and filter like the advice was given and I hold great pressure.
I also adjusted the time 10 degrees above like factory specs but that seem to effect it any. Does anybody have any advice? Could I be dropping to much gas into the motor with the constant pressure of the throttle body? Could the timing be advanced way to high with the cam?
Thanks for the help you guys have been great and saved me a lot of money! Hopefully this issue is an easy fix the motor runs smooth and can really lay some rubber, Just need to it stay running at a traffic light and i would love it
