Starter Bench Test
I use a jumper pack, or jumper cables. Ground to the case. Hot to BOTH small and big terminal. make sure it spins AND the gimble kicks out.
Update: It doesn't work. The bendix kicks out, but it doesn't spin. I figured it will cost too much to ship back to CA. from NJ., so I opened it up.
Few new parts. They apparently use a cleaned and painted case w/new lugs, then put old parts in it. The armature looks to have been cleaned up w/ emery. The brushes are okay, but not new.
Looking back, the ad doesn't say new, rebuilt, used or otherwise. I feel like a fool, this a**hole got me.
I ordered it based post #21 in this thread:what-mini-starter-are-you-using.404177
Hope I can prevent others from getting the shaft.
Johnny Mac, got you in mind...
Just open the ebay options and click return because it's defective. You aren't stuck with it. Should generate a free return label.
The description does say, "100% buyer satisfaction," and there is an eBay money back guarantee. IMO, even the return shipping charges should not be your responsibility. Just don't wait too long before time limits expire.
