Gadabout
The old one, probably 1960, has bad brushes. Ordered a new starter that indicated it would fit a '60, but when trying to install it, the bolt holes match up, but the pinion gear does not reach the flywheel. Any ideas?
Here is your 1960 slant 6 starter.
Wonder if it might even be a 6 volt starter???
id personally send that one back
buy a similar one off rockauto rebuilt (1996 5.2 engine)
and swap the pinion
job done
Thank you all again for your exceptional knowledge and experience. I went through the conversion chart for Speedway Motors and spent $400 on a starter. The bolt holes lined up perfectly, but the Bendix would not reach the flywheel.Sloppy/ignorant vendor. No, that starter will not work on your '60, or anyone else's '60 or '61. Info you need is in this thread.
that's a wonderful end to the saga.Thank you all again for your exceptional knowledge and experience. I went through the conversion chart for Speedway Motors and spent $400 on a starter. The bolt holes lined up perfectly, but the Bendix would not reach the flywheel.
Rick at Show-n-Go Automotive here in El Paso went through his Rolodex and found someone who would rebuild it, which they did, got the wiring exactly right. Rick kindly took the time to explain to me the unique features of this vintage starter, and was something about not having a solenoid and having some vintage electrical switches that wired into the park mode on the transmission. Cost: $65 plus install.
This is not just a problem isolated to the 60 and 61 slant sixes. Matt and I has an original, unmolested 68 Dodge D100 with a 318 and a 904.
well a 318 with a 904 in australia uses a 9 tooth 25 mm pinion
OR
a 10 tooth 27 mm pinion that is moved out by 1 MM in the starter snout.
But their 727 with a 360 in front, uses the 35 mm pinion the US knows and loves
and they have slants that can't use that starter or the two above
South africa picked from the south american and australian parts bins so its a bit more confused
one could say its a bit of a mine field
rule of thumb right hand drive bellhousing 25mm 9 tooth pinion
