Starter question for a-833 trans
Manual Transmission & Clutch Discussions
  1. Robin House
    Robin House Well-Known Member
    69
    14
    Jun 6, 2016
    Ontario
    Local Time:
    10:57 AM
    this is my 2nd post tonight! Lol
    Ok so I also just realized the new mini starter I bought last year will not work with the fly wheel setup on the Manuel transmission. Are the starters different for auto and Manuel trans? If so what type of starter do I need?
  2. teringer
    teringer Well-Known Member
    919
    247
    Feb 22, 2011
    kenly nc
    Local Time:
    9:57 AM
    what is wrong with it is it hitting the block?
  3. lilnoah
    lilnoah Supercharged slant six with 4 speed and 8.25
    528
    262
    Dec 22, 2014
    Murfreesboro, TN
    Local Time:
    9:57 AM
    I switched from 904 to a833 and switched to a mini starter and had no issues. My mini starter was from Powermaster.
    • Like Like x 1
    • Agree Agree x 1
    • Robin House
      69
      14
      Jun 6, 2016
      Ontario
      Local Time:
      10:57 AM
      No it fits on nice. But check out the gap between the starter cog and the flywheel teeth
    • Robin House
      69
      14
      Jun 6, 2016
      Ontario
      Local Time:
      10:57 AM
      Yea but I put the mini on when I had the 727 auto. I’m thinking there a diff between the auto and Manuel. Just want to be sure before I go spend more cash
    • teringer
      919
      247
      Feb 22, 2011
      kenly nc
      Local Time:
      9:57 AM
      does it grind ? is it too tight or too far away when cranking?
    • j par
      j par Well-hung Member
      28,791
      16717
      Jul 2, 2014
      Portland Oregon
      Local Time:
      7:57 AM
      My personal experience with the powermaster was it was a pile. I got one at the U Pull It Out of a Dodge Ram and I absolutely love it. I hope your serves you better than mine served me..
    • lilnoah
      528
      262
      Dec 22, 2014
      Murfreesboro, TN
      Local Time:
      9:57 AM
      Mine has worked well for me.
      • Like Like x 1
      • 5.7 hemi
        5.7 hemi FABO Gold Member FABO Gold Member
        3,533
        3111
        Apr 18, 2009
        Local Time:
        9:57 AM
        It’s fine. Use it as is and don’t look back.
      • my68barracuda
        my68barracuda Well-Known Member
        2,098
        1990
        Dec 6, 2009
        Indianapolis IN
        Local Time:
        10:57 AM
        The same mini starter will fit and work with either manual or automatic transmissions.
        Are you sure you have the correct flywheel for the bell housing that you are running?
        • Agree Agree x 1
        • Robin House
          69
          14
          Jun 6, 2016
          Ontario
          Local Time:
          10:57 AM
          No I am not 100% sure. Bought it used as a package.
        • pishta
          pishta I know I'm right....
          21,733
          11136
          Oct 13, 2004
          Tustin, CA
          Local Time:
          7:57 AM
          is the snout buried in the 2nd pic? Looks like its in crooked?
        • d55dave
          d55dave Well-Known Member
          2,539
          1048
          May 20, 2010
          Kelowna, British Columbia
          Local Time:
          9:57 AM
          As was asked before, what is wrong with the picture? The small gear slides to engage the flywheel when the starter is energized. Same starter for manual and auto, big block, small block and slant six with a couple of exceptions.
        • RichardJ916
          RichardJ916 Well-Known Member
          1,059
          203
          Jun 30, 2010
          Howell Michigan
          Local Time:
          10:57 AM
        • duster360
          duster360 Well-Known Member
          3,825
          359
          Aug 8, 2008
          Alabama
          Local Time:
          9:57 AM
          Looks fine to me.
        • Robin House
          69
          14
          Jun 6, 2016
          Ontario
          Local Time:
          10:57 AM
          Ok, thanks for all the posts guys. I’m going to pull it out, take a look and reinstall. I just don’t think it’s going in close enough to engage.
        • TheGrateRonzini
          TheGrateRonzini FABO Gold Member FABO Gold Member
          968
          836
          Oct 25, 2017
          Western New York
          Local Time:
          10:57 AM
          Try and grab the bendix by hand and rotate twords the flywheel. It doesn’t appear any further than normal
          • Agree Agree x 1
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            52,373
            21510
            Oct 14, 2010
            Idaho
            Local Time:
            7:57 AM
            Please be clear..........it wont work at all? It grinds? "It what?" You don't have the wrong size flywheel because it would be wwwwwaaayyyy far off so if the starter is correct (For a Dodge V8 magnum) then it's a defective starter
          • AJ/FormS
            AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
            22,043
            9219
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            Local Time:
            9:57 AM
            When you energize the starter the pinion gear will jump rearward into the flywheel. Then it will begin to spin the engine. Then when you release the key, the starter gear will return to the parked position, as you now see it.
          • j par
            28,791
            16717
            Jul 2, 2014
            Portland Oregon
            Local Time:
            7:57 AM
            I swear it was 318 has valves that will fly that told me about the junkyard starter. But I swear that $22 U-Pull-It starter has been one of the finest units I've ever had. I wouldn't waste my money on anything else ever again if I ever have to for that matter. yeah it was greasy and ugly when I got it but after I shot it with WD-40 and wiped it off and shot it with some more WD-40 and kept wiping it off I did it a third time it came whisper clean.
          • Robin House
            69
            14
            Jun 6, 2016
            Ontario
            Local Time:
            10:57 AM
            Thanks again guys. I pulled it off and reseated the starter. I think it will work.
            • Like Like x 1
            • goldduster318
              goldduster318 Overzealous Car Modifier
              1,764
              338
              Aug 25, 2007
              Lake Orion, MI
              Local Time:
              10:57 AM
              You probably need either a shim (Van's auto sells on ebay) or the steel shim plate and it will probably fix it if it grinds or sticks
