Strange246, this thread brought back some great memories. I was going to just post a link to this (it's kinda long) but unless you're a member of the BarracudaOwnersGroup, it wouldn't show up. Forgive me for the excessive use of space in your thread. Thought ya'll might get a kick outta this.
November 10, 2005 (a couple months after Hurricane Katrina btw)
The day started off normal enough. Had to cash the Red Cross check (wow, that's a first), hit the hardware store for some valve cover bolts and washers, and get five gallons of gas.
On the way out of the bank the cell phone rings. Of course, it's Billy. "Did ya go to the hardware store yet? No? Well, stop by the house first. I've got a big problem here."
Uh ohhhhh ... He's at home playing with my car. I don't wanna hear about problems. Especially big ones. Finished up getting the radiator, overflow tank and fan shroud in a couple days ago. The new seats and steering wheel were installed as of yesterday afternoon (grrrrrrrr forgot to order a dang horn button), and the Fed Ex guy delivered the Optima battery at 7:35 this morning.
Today's The Day.
The "big problem" was minor, though -- a couple brass plugs for the intake just needed to be added to the hardware store list. What a crisis.
Now armed with my brass plugs, stainless bolts and washers and 93 octane, I got home to find the fan belts were on, the alternator was adjusted and the red-top battery was installed in the box -- and it looks great too. We bolted down the valve covers and put the radiator hoses on, then I poured in Castrol and four quarts of ATF while Billy poured gas in the virgin tank and checked for leaks. Then I filled up the radiator and checked all the fluid levels again. Perfect!
The master cylinder was bled first (only a few drips went where they weren't supposed to), and then three of the lines. Brake fluid all over the ground on the driver's side suggested a problem somewhere [hey Steve can I borrow your kitty litter???]. Some pedal-pumping and investigation revealed the new line-lock fitting wasn't tightening up enough. It was a quick fix with the flaring tool, and the final brake line was bled. A serious push on the pedal will throw ya through the windshield now! Gotta love those Aerospace disc brakes ... mmmm mmmmm.
While I rummaged around what's left of the kitchen and finally found the fire extinguisher, Billy hooked the battery cables up. I grabbed the keys, opened the driver's door, and was somewhat shocked that interior lights came on in the back seat. Wowwww -- I've never seen my car do that before. I had to turn around in the seat and admire them again once I got in.
Is it really happening??? Fourteen and a half years of learning about this thing inside and out, tons of hard work, mistakes, parts collecting, saving up for stuff, waiting, wishing and hoping it would turn out even half as good as it has were now coming to an end.
"Kick it in the nuts babe." I held my breath, put the key in the ignition, and rolled it a quarter turn to the right.
N o t h i n g.
He peeked around the edge of the hood and looked at me expectantly. "Wellllll???" I shook my head. He looked puzzled; then checked the MSD box and fiddled around with the distributor for a minute. "Try it again." I turned the key again. Still no response from the car. I made sure the ignition switch was wired up and anticipated a phone call to Advance Auto Parts ... but he was finding a piece of wire and a long screwdriver. (A faulty ignition switch wasn't going to foil ol' Billy Lee, nooooo way.)
I'm not one bit ashamed to admit that I cried like a friggin baby when the screwdriver touched the lead and that bad *** billeted ***** fired up for the very first time. VahhhhhrrrrrOOOOOMMMMM racketa-racketa-racketa ... 400+ horsepower came to life ... the ground shook under my feet ... the cam action rocked the car back and forth ... 68 pounds of oil pressure?!?! Ohhhhh my goddddddddddd ... SLIMER LIVES!!!!!!
Walked around to the passenger side to see 8 1/2 pounds showing on the fuel pressure gauge, and a big oil slick forming behind the front tire. Shut 'er down!!! It lost almost a quart while figuring out the big oil filter adapter bolt didn't get tightened all the way after the final header adjustment was made in April. Whoops. Glad I bought a whole case of that 20/50.
There were no other leaks, it ran perfectly, and fully petrified the neighbors and small animals. The smells of baking fresh paint and high octane were thick in the air.
Of course, I also had to honor Dana the Trim Master with a quick trip to the back to admire my 1968 tail light lenses glowing red in the now dark garage. Awesome!!!
So aside from a couple of mild chemical sacrifices (watch for me on the EPA's Most Wanted), The Day Slimer Finally Ran was a total and complete success. I would have cracked open my sole BOG beer if I had had the forethought to put it in the fridge ahead of time. I raised my glass of chocolate milk and saluted all of you instead. It was the biggest imaginary group hug ever.
I didn't get to actually drive it anywhere yet though. My drive shaft is an inch too long, I still need a short section of linkage from the console down, there's that ignition switch problem, and I'll need some sort of exhaust system. But hey ... it runs.
To hell with Hurricane Katrina. Life is good again.
Leanna ~ The CudaChick ... who can build something that actually works
1968 Fastback 340
