ValiantOne
I've been doing a gasket kit resealing of my motor which is a 68 273.
My Fel Pro kit came with both steel and a composite intake gasket. The existing gaskets were steel. Do I have to use the steel ones when re assembling?
If so how in the heck does the water crossover seal? Does steel on steel do it? Or is some goop in order?
If not is there any reason to go with the composite? Mo' betta? Worse? Indifferent?
I've done a few intakes but never one with steel on steel like this. Just want to do it right!
Thanks,
CE
Thanks,
CE
