steering column-which u joint
rbkt65
jerseyville, illinois.
if getting rid of stock mopar connection at the steering gear box, which u joint is used to replace it? tia
3/4" Round X 3/4-36 Black Powder Coated IMCA Racing Steering U Joint Coupler NEW | eBay
This is what I’m using, for manual steering.
pricey parts, aren't they. thanks. the last borgeson ones aren't too bad.
considering the job they do, I'd say it's money well spent.
you didn't say what the application was, so I figured to just link the widest array of popular choices. obviously you could do some legwork and find something cheaper off ebay or from another supplier. midnight linked a suitable alternative for much cheaper.
The factory coupler allows for fore and aft movement. The aftermarket U-joint does not. I see a possibility for more vibration over the factory piece, but I don't see an advantage.
Rusty, I installed an aftermarket tilt column. I am using a 1" dd to 3/4" dd from the column. 3/4" dd shaft to the Borgeson u joint, 014921, that I ordered. I searched the Borgeson site and this is the number that I came up with. I was concerned with the vibration, but after study, I decided that i would go this way. We will see.
Update on my junk. After ordering 3 different 5/8-36 spline u joints and getting ones that don't fit, I ordered the Borgeson 86.00 one and it fits like a glove. 3x the price of the other ones but it is what it is. Also I went to the junk yard and got the body side wiring connector from and early 80's Gm and will use it to make a jumper to my factory wiring harness. No ign switch on column, so will use a part of the orig switch harness to make another jumper to my universal 4 pin marine ign switch.
I also, did the swap man the steering feels great ride nice I got mine from speed way
I personally did not notice any extra vibration when switching from a stock mopar steering adapter to a borgeson one.
Me either and there’s some shitty roads on my way to work lol
What did you use for an aftermarket column? I am interested in doing the same in my 73.
Didn’t use a aftermarket column I just removed the column and trimmed all the excess sleeve etc
