frumharlem
Active Member
I noticed a small spark when I turned the key a position. The little black/ charcoal gray cam the bitches into the cylinder lock was where is sparked from. I the. Noticed there is some lateral play in my shaft. The shaft kind of has a flat taper in that section.
but with the okay, the steel shaft ca definitely touch that ignition switch cam. if that supposed to happen?
I taped the shaft to prevent the arc if it touched on the road.
see pics
