Converting from power to Manual sterring on 68 dart. Bought Flaming river power to manual adapter and sterring box from Mancini. Question is coupler has 1 hole in the piece that the sterring column will slip into, sterring coulumn has a hole through that the supplied roll pin will attach but the coupler does not have a through hole. It seems it should be drilled both sides, slip in sterring shaft drive in roll pin, but with 1 hole pin will not go all the way through. Is this a mistake? Do i need to drill this coupler so the hole is through?
Thanks
Thanks
