Well, actual numbers can be found on the net but, it's enuff to power a decently powered engine. I think there something like 70 gph @ 5 psi.
I'm not sure on the exact numbers.
I have a cheap carter M6866. It leaks out the top if it drys out before start up. I guess I'll get another one. Not much to choose from unless you want high flow/pressure pump for normal driving.
