Stop in for a cup of coffee
Two?!? It killed chains on 2, 24 inch, 5 hp saws & 2 chains on the 9 hp saw!
Maybe it's like cutting and drilling stainless. You may need to slow down. When I started working with the stuff I was burning up carbide bits and Sawzall blades. Found that a fresh HSS bit on slow and a hack saw did the job.
Maybe, just maybe you could move the saw a few inches Left or Right to get off the nails!
Have seen that too. In trees in the middle of nowhere.
Also good size stones too.
A friend has a bandsaw lumber mill. Trashed a few blades on things buried deep in the trunk.
May want to look into sharpening
Method for the chain.
Also,brand of chain matters.
I found the stihl chain is about the best. But you need stihl files to sharpen it.
Then there is carbide chain.
Better yet, if that timber has some value, maybe someone will take it down for free.
They are stihl chains. And stihl saws. Brand new chains. And we do sharpen them. Have been for decades. Our heat source is wood. I’ve cut bunch of wood in my life. Just never ran into this before.
Tried from all over the tree. Multiple places, after about 1/2 inch, just smokes. So either there’s an iron case a half inch deep or it’s just a dense *** wood
di it cut when you started?
Sounds like its heating up yor chain and losing the edge. Pretty much what stainless does except with that the metal actually hardens with the heat. Compounding the problem.
about like normal
could be. I even tried the aggressive side cut ones we normally use in big oaks. Dulled within seconds. I may do as TMM suggested and try a much slower cut
Could be the sapwood is softer and the heartwood is killing the chain. But I still think its the heat. If you have a good sharp hand saw...Bow saw maybe, Give it a try.
Yeah I’ve got a good double cut timber saw. Will have to get some help on it, it’s 6 feet long.
Hmmm I wonder if maybe I have too aggressive of chains on them. Two months ago, I bought the super aggressive, fast cutting chains from the local stihl dealer as an upgrade over the standard chains. Maybe I oughta try the standards on this tree.
Yup, Even a skip tooth chain, might be better, But its still moving same speed. Maybe shallow cuts and back off to cool? Run water on it?
Super aggressive fast cutting chain?
If your saw and bar combination
Takes 3/8,.050 chain then thats what it takes.
The safety chain im sure has never been on any of your saws.
Its useless.
3/8.058 chain is one chain made to fit the guage and pitch. A ripping chain is usually a reground chain with almost a square cut to keep it from following the grain in the wood.
I would like to see a good close up photo of your burned up chain,
Especially the condition of the cutting link.
