O no problem chokin on my rod! Short or not! We are talkin Carbs here, right?![]()
Why can't it be both???
TMI....
I would figure some way to lengthen the rod.
so now your rod is longer than it was before?
Cannot have to long a rod, still Carbs?![]()
The bolts are too small. Stay on the crank if you can.
You can take off teeth if you pull too hard with one of those.
Choke rod, cut a slot in a 1/4” or 5/16” bolt. Put over rods and snug up a nut.
Thats actually what I was gonna do. I need to find one or maybe just go get a grade 8 one for the front of the crank.
Hard to find one at the hardware store.
I just happened to flip past the Weather Channel yesterday when they were talking about the Southwest. The powers that be have "officially" decided that we are having an El Nino event.They didn't say which of the 3 documented varieties this is.
Going to throw up a couple of nos coils later and a nos vac advance.
build you a tornado shelter
It is all kind of in flux.....
I just read an article on the dangers of drinking and it scared the crap outta me. So after today, no more reading
