Stop in for a cup of coffee
Sweet. I might try it. There is only one shop who will polish a crank without having to really drive far and the guy there ups the price everytime and he takes longer everytime and he won't help me unload the crank. He just stands there and watches me try to lug a heavy *** crank in the front door. Kinda rude, so if I don't need him..... SWEET
A lot of guys will argue the 320 and say use 400. There's nothing wrong with the finish 320 leaves. It gets the job done faster. It takes 400 forever and a day.
And screw that guy. He has you over a barrel and knows it. He's probably a perv too checkin you out unloadin all that stuff. Find another shop even if you have to drive farther. Simple. Just consolidate your machine shop trips. I'd be callin around and finding one.
I live near New Braunfels, Tx and drive to Houma, La to get in a carryall to either catch a helicopter or another boat to my boat. Still cheaper to drive than it is to fly into New Orleans
What do you do on a boat? In New Orleans? From Texas? LOL
320 dry or wet??
Wet is going to be pretty aggressive
I work as a martime engineer. Think mechanic and janitor all in one. Hydraulic, electric, mechanical, sewage, watermakers, hvac, pneumatic and electronics. Jack of all trades master of none. It is oilfield related. I work 14 days on 14 off.
Ok, you're the guy nobody wants his job. I got it now.
Sounds like a tough job.
Kano Kroil is another good one but pricey. I use it over anything else to loosen bolts.
I used to use that stuff because I had access to it though a shop I worked at but after I quit that shop, I can't find it anywhere now so i resorted to PB blaster through o'Reilly's, because I have an o'Reilly's very near in a rural area
Wax On, Wax Off
if you don’t have any penetrating lubricant on hand or you want to try another technique, the wax method may be your savior. Long before Norm Larsen figured out the formula for WD-40, mechanics were using wax to do their dirty work. All you need is some paraffin wax (candle wax) and a source of focused heat. A propane torch or a heat gun should be used to gently heat the fastener. In this case, you don’t have to get it too hot, just warm enough to melt the wax. Once the metal is warm enough, touch the candle to the fastener around the edges and allow the wax to melt. The heat will pull the wax into the gaps between the bolt and nut threads and allow for easier turning. Remember that the wax will tend to flow to the heat source, so heat the bottom threads the most.
I was an alignment tech in almost every dealership in Macon at one time or another so I know all about gettin the jobs nobody else wanted ........or could figure out. Probably why I have such a wide range of experience. I never turned anything down. Squeaks, rattles, driveability.....whatever.
Wish I could show yall the photos I have from some guys grinding the crankshaft on a Nordberg slow speed diesel. They did it in the block with fixtures. The main pin was bigger than 15" in diameter.
