I think there is more than one conversation going onYeah that's it chris get a oil filter socket put the impact gun on it and give it a try on high setting! CW of course it is a la.
It's only a dumb idea if it doesn't workYeah that's it chris get a oil filter socket put the impact gun on it and give it a try on high setting! CW of course it is a la.
Or a you tube video!It's only a dumb idea if it doesn't work
He is in la la land. They turn everything CCCW.Yeah that's it chris get a oil filter socket put the impact gun on it and give it a try on high setting! CW of course it is a la.
Yup, its burnt.This is why chicks make good mechanics.
I am doing a customer job and a big burly guy I know attempted the job but couldn't "get his hands on anything" it's a burnt a/c compressor.
Not only did I get my hands in there, I got my whole arm in one side to wedge it out
Girl power whoop whoop girl power
If I loosen the bolt I can rotate the hole thing, but the clips are like new and are very tight on the capCan you turn it at all by hand? Up down side to side?
Um... OKHeres a slant socket same as a la but two less bosses. Just FYI
The cap!
Oh the hood grounding device egh?
No, just the cap and no, it doesn’t move when o try by handThe cap! the distrib is not wobbling or is it?
The cap or the whole distributor?No, just the cap and no, it doesn’t move when o try by hand
Yes very, and yes I made sure the slot lined upHey was the rotor hard to push down at first when you installed it? Should easily push on.
CapThe cap or the whole distributor?
Lol I’m sureYou fucked something up then no idea what. We pretty much covered it all that can do it, loose distrib, bent shaft, rotor not seated and cap not seated now I am lost. Still pull the rotor and put the cap on and see????
Could I have mistakenly tried putting a big block one on it? I have bothYou fucked something up then no idea what. We pretty much covered it all that can do it, loose distrib, bent shaft, rotor not seated and cap not seated now I am lost. Still pull the rotor and put the cap on and see????
