Stop in for a cup of coffee
Bring that box to Carlisle we will get it cold somehow to test it.
Would need dry ice. It was under 25F yesterday. I really think that was more the battery than anything. It's a bit undersized for that original starter and was likely a little low from not being run. That reminds me, need to take neg off before I tighten up the cover...
Been doing some laminate flooring for the guy who's deck I rebuilt a while back. Still have one bedroom and a bathroom to do and the whole place will be done. He wanted the kitchen and dining done over exiting vinyl + underlay. So had to do transitions for the different levels.
Looks like a lot of work
Looks like a lot of my dew breaks are in order
You do nice work. I may have to recruit/kidnap you!
I just finished making about 3 gallons of sausage gravy. Having a big Christmas brunch at work tomorrow. I'm in charge of biscuits & gravy and Belgian waffles. Another guy will fry up 10 pounds of bacon and deep fry hash browns. The ladies handle scrambling up about 5 dozen eggs.
I have vodka and several choices of juice.. Should be a good morning!
Okay, now this is weird. I was checking my timing on this and noticed that the cap on the dizzy is rocking as it turns over! Both snaps are on and good. It’s fully seated down and yes the dizzy bolt is tight. I can shake it and it doesn’t budge but under cranking it is. Stumped
Better yank that distributor out and see whats up. A missing clip or damaged/bent dist drive.
Check for a bent distributor shaft.
No different than the fargo, i will have left no stone unturned by the time i get all the mechanicals sorted out. Always something.
Will do, hope it’s not, i broke down and put in the good one from hoppy. Not only that but I checked it before installing. Unless I didn’t get it in the slot all the way somehow and bent it :BangHead: that would be my luck
Chris take the cap and rotor off and crank it and look at where the rotor would be and is it wobbling?
It wasn’t when I was checking to make sure the points were opening and closing, they were
