Stop in for a cup of coffee
I have a buddy who is a bit of a Holley savant. Does rebuilds as a side gig.
I turned it over and drained it out. Took the acc pump cover off and sprayed it with carb spray and dumped it out. I sprayed inside the fuel inlet and the acc pump cavity and dumped it out. I put it back together and put it on and it did idle a bit better and no hesitation. I didn't think to check until I was driving back to the storage garage, it might have manifold vacuum to the distributor which I am not a fan of. There is too much rpm difference between drive and neutral. Just sayin. The AVS II will take care of that. The B body guys that have put 4 barrels on their Teens say it makes the world of difference.
I had to play around a bit with the vacuum connection and making sure the unused ones were unplugged, but the 4 barrel rocks.
I did rework the linkage using that Master Mechanic supplement. Much happier with the range and angles
bahaha BRITTNEY GRINER is facing a two-game suspension and a $150.000 fine as the WNBA investigates allegations she made racist comments toward Catlin Clark.
Friday Eve kids
All you folks migrating to MITP be safe out there. Fred is on the move with the Little Red Weiner Wagon, full of fresh arses.
Good Evening All! Stopped by to see a car for sale on the way home, same house as the guy with the 68 Cornet. Snapped a couple pics, rare car I think, will post a "Name that Car" in the morning, sure you'll get it but I'd never seen one...
