Stop in for a cup of coffee
I bought one of these a while back. Works great no air line to drag around. Shoots anything.
Cordless Spray Paint Gun,Airless Paint Sprayer Paint with 2Pcs 1500mAh Battery,Easy to Clean 5 Nozzles Electric HVLP Paint Sprayer for House Painting...
Color:Red+Black
They even have one that takes my Milwaukee batteries. Nice
Color:Red+Black
Would you paint an entire car with it?
Color:Red+Black
How much do them big batteries weigh? Make a little clip to hang battery on the artist's belt with the proper electrical cord connection. Make that hand a lot less fatigued.
Not. Heavy at all. At least not to me.
I will weigh one and get back to you.
Not a bad deal for $70.00
This snap-on blast cabinet................................. Does anyone know if when you plug it in, the light and fan should come on, or does it need air pressure as well to operate? I have never used one, and I plugged it in the other day and flipped the switch, and nothing.
The Air and Electric should operate separately. Your bulb might need replaced. Or maybe the switch is bad .Mine doesn't have a fan, so I don't know about that. Air just supplies the pressure behind the media. Most Blast Cabinets operate pretty much the same....
Nice thing about doing those blast projects at the rock farm. BIGASS compressor and run over the spent sand and debris with the skidsteer tractor, no clean up! :lol: Just blended right in with the rest of the dirt :lol:
Left brake lights not working on the Polara. The turn signals work so I know the bulbs and ground are good on that side. I looked at the wiring and remove a couple of those goofy splices for trailer lights and taped up the wires. Still no lights on that side. I came in and printed off a wiring diagram. It's the brown wire going up the left rail to the kick panel. Pull the carpet loose, pry the cover back and find the wire' getting ready to poke and test with a test light. I go back and look and see the lights are lit. FFS I look at all the wires from the kick panel to the trunk and don't find an issue. WTF.. I need to by a lottery ticket. Good luck is on my side. I can fix stuff without really fixing it. :rofl: :rofl: :rofl:
Color:Red+Black
Never tried one but looks real handy.
Left brake lights not working on the Polara. The turn signals work so I know the bulbs and ground are good on that side. I looked at the wiring and remove a couple of those goofy splices for trailer lights and taped up the wires. Still no lights. I came in and printed off a wiring diagram. It's the brown wire going up the left rail to the kick panel. Pull the carpet loose, pry the cover back and find the wire getting ready to poke and test with a test light. I go back and look and see the lights are lit. FFS I look all the wires over from kick panel to the trunk and don't find an issue. WTF.. I need to by a lottery ticket. Good luck is on my side. I can fix stuff without really fixing it. :rofl: :rofl: :rofl:
:rofl::rofl:
Who knew the Ban Hammer worked on electrical issues
Tells me you gots a short somewhere… but ignore me, I’m sparky
We had a big rain system heading straight to us this morning near 10 am, it broke down some a headed north, so glad it did, I see a lot of rain going down that road.
Here's the finished product. The K-frame has been painted in semi-gloss black. Turned out pretty good. The goal is to have every other part of the car looking this good before it goes back in the car.
View attachment 1716414948View attachment 1716414949
Looks perfect, that is my go to paint as well, congratulations
My old ramcharger had a similar brake light problem and it was a connection where the connection of two wires to one was just moves around enough to test them with mt needle tester, like yours, I did nothing and I looked at the reflection off the wall and it was working, old corroded connection from factory had been getting wet on mine Mike, it was sodered but I could wiggle one wire a little. Yep, I got lucky then, moisture was the culprit
