Weather channel says 91° here in Friendship MD. Only 82° inside my shop with the fans on and the doors open. I'm still working.
I left the party. It got real stupid.How in the WORLD can it be SO difficult to tap on an adjuster hole in a rocker arm to tighten it up? I mean really.
Throw some cold water on it.How in the WORLD can it be SO difficult to tap on an adjuster hole in a rocker arm to tighten it up? I mean really.
Yep, just glue them in.How in the WORLD can it be SO difficult to tap on an adjuster hole in a rocker arm to tighten it up? I mean really.
I'm bettin Locktite will never hold that application, because of the vertical forces on the adjuster. It's simply not the right thing or the job.Yep, just glue them in.![]()
LOLThrow some cold water on it.
Well FFS Chris....When it rains huh ?Well... it's worse now with no spark.
I swapped out the ballast, coil, voltage regulator, ECU, and distributor pick up. Ran tests on everything.
Looking for a shaman now
Fu$% this carWell FFS Chris....When it rains huh ?
Good engine ground. Probably already been asked.Fu$% this car
I'm done with it consuming my time and money.
Yes.Good engine ground. Probably already been asked.
This is the sequenceFrustrating no doubt………![]()
Hoppy had no input?This is the sequence
1. Installed new motor
2. Installed transmission
3. Car started, second try
4. Adjusted timing
5. Test drove and had Indication of transmission issues
6. Backed into the garage, put on jack stands
7. Supported motor and removed transmission
8. Installed transmission
9. Relocated starter solenoid about 1" to get some space from the distributor.
Car hasn't started since.
But, apparently it eats rotors...
No hail, but raining on and off all day.Raining in buckets here with a bit of hail.
Distributor touched firewall, supposed to at least pull cap off.This is the sequence
4. Adjusted timing
Willie have you tried a new starter relay switch. Plus make sure the ECU has a good ground.Well... it's worse now with no spark.
Ordered one this morning. ThanksWillie have you tried a new starter relay switch. Plus make sure the ECU has a good ground.
"I know you bbqed and there are leftovers. I want my share, or the drapes get it!"
