Stop in for a cup of coffee
So, I guess the self diagnostics doesn’t give all the codes. Got this with the reader. I went for the easy fix and cleaned the seals on gas cap. (It was dirty) Cleared the code, so will wait and see.
Still in the rough but the door to fender is straight from bottom to top.
Yes sir, looks good Fred, my neck hurts just thinking about blocking, but I work smarter at my age and know when to stop for an hour, to much repetitive motion at one sitting was the last thing on my mind at 40
Good work
Got started, made it to the splash shield, all strapped in with rubber straps and a sleeve, this goes straight to the fuel pump.. going to travel down the inside of pinch weld, I have 3 stickers to put on the outer pinch weld ( fuel line ) with arrows on each end.
Yep. My Jeep gets that code. Notorious problem for them. The factory metal of the filler neck has poor QC and not even factory gas caps will seal up all the way after a few months of use. I just ignore it
Good work
I sand the bondo down when it is not quite cured on the first coat and makes it a lot easier to sand. I'm defiantly getting older and need a break now and then.
Same here, catch it green and soft to cut with 80 grit if I remember right, I hear yeah Fred, I can smell body filler right now.
I been using body filler so much I can't smell it anymore. And fiberglass has no smell to me, I guess I'm pickled. LOL
Good morning everyone. Back to the grind. I guess my brother from Alaska is in the state. I hope to see him on Friday, so I will leave work early and run up by mom.
