Stop in for a cup of coffee
I have the same HF 20 ton press also! Cheap but does everything I need axels are fun though!
That needs to go into the tips and tricks thread for sure. I have prob cut 7 bearings doing 8 1/4's Now rons jeep might have to be done also. Hope his new diff has the same design as the ols one and no crush collar. Dam jeep there is barely any thing I can find on the five different dana 30 carriers and they can go both ways shims under the bearing or a shin pack under the front bearing with a crush type shim, much easier set up for sure.
For the limited amount of use I give it, it does just fine. And since the price was right (free), I couldn't pass it up...
Weld the areas where the bolts hold it together much more steady for sure. I just want to make a different adjustable shelf? and make it wider to do axel bearing easier.
I have a customer that drives axle bearings on with a piece of exhaust pipe. Crude but it works.
Mike what do you get for a good separator with a really thin face say 5" wide or so.
so it looks like I've decided on the lower quarter panel patch instead of a skin, 86 bucks and in stock. Just have to measure to make sure it covers where i need
probably save on shipping if you get your floor pans at the same time.:thumbsup: jes sayin...:D
yep, 37 bucks to ship it all. grand total of 240 bucks...... still less than the entire AMD skin.... hmmm
